Dometic toilet
Rver2020
Just bought a new dometic 300
Toilet late last year - used for a few months. This spring we noticed the seal leaks water in the toilet bowl, so we can’t keep water in it. Suggestions?
Before you take it apart and replace the seal, try this. Sometimes the ball gets out of round just a smidge and the seal doesn't seat properly. With a gloved hand, reach down and hold the ball while you also (gently) begin to flush (don't let the ball rotate with the flushing motion for just the beginning of the flushing motion.) Perhaps this will realign the seal. IF not, then proceed with seal replacement. Blessings
You can also try cleaning the seal then using waterproofgrease on it. There is also a toilet seal lubricant you can use on a regular basis to preserve the seal. And yes, never let it dry out.
Similar issue. Did you ever find a solution? The guys at rvtoiletparts.com suggested a new seal, but hoping to avoid the work involved in that....
Another trick is to pour hot water into the toilet. Mine stopped leaking with the cleaning and waterproof silicone grease or faucet grease, and toilet seal lubricants. I bought new seals, which are actually easy to replace, but as yet have not needed them. Just checked yesterday. Water still in there after two weeks sitting. When I put it away , I pour some toilet seal lubricants into the water already in the toilet. Five years and still on the original seal.
