Question Electric Headache
Jaxs
Hey there, looking for some advice. I have 1998 Fleetwood Discovery 36T. All the 110 GFI outlets are not working. When I use a tester I get a hot/neutral is reversed indicator. Check all the wiring everything seems to be correct. Has anyone ever had this issues or can give me an idea where or what I'm missing. Thanks.
Welcome to RVforums from Ely, Iowa. Have the outlets been working, OK? If so, go the main GFI that has the reset test button on it and see if it is tripped. Also not knowing your system go to your inverter and check the breakers on the inverter and see if one of them is tripped. If the outlets have not worked since you bought the rig, then you probably need to get an electrician unless you are comfortable getting into the panel.
I know I should know this, but, how will a tester give a reading if the outlet has no power?
