Electric problem
James
2018 highland ridge utra light lights above dining table and lights above recliners and my electric receptacle are nothing working but fuse is good can anyone help thanks
Have you checked your breakers?
No sir a have not are they located in the same panel
To be honest, I have no idea where your panel is located, but it shouldn't be that hard to locate. Many times it's going to be under the bed, or in that general vicinity.
Quick question, are any of the outlets in your RV working? Or are they all dead?
I will get my owners manual tomorrow afternoon and see because I now they not under the bed I will let you know how it goes and thank you for your help
Hi, @James; welcome to RVF. Glad to have you here with us.
Are the lights and receptacle that aren't working 12VDC or 120VAC? Generally, 12VDC things have fuses, 120VAC things have breakers.
Double check that fuse. Easy to think they are good, especially if it’s your big boy fuse between the battery and inverter. Use a voltmeter to verify current is passing through the fuse.
Thank you TJ I will get back on it this afternoon thanks for your help I’ll keep you posted again thank you
