I could not find one anywhere so I built one. Bought a harness pigtail that you would wire into the truck. I joined all the leads for the lights (tail lights, brake lights and the tag light), tie in the wire that goes to the fuse panel, put alligator clips on the bundle and on the negative lead. If connected to shore power, disconnect it. Plug the harness into your trailer, take your battery off line and connect the clips onto the trailers battery. All exterior lights should come on, as well as interior lights. Just don't connect the blue wire unless you want to test the brakes as well.. Once the harness is built, all you need to do is plug it into the trailer, open the battery isolation switch, connect the leads and look.
