Electrical Issues. Please help
Seldom is a house battery a battery! Rather it is a battery bank(more than one). The ones that are tied together.
Ok, I know where those are. There’s some tied together and I think next to that is the other battery/batteries
You likely have a Xantrex Freedom 458 converter/ 2000W modified sine wave inverter located in 2nd last bay next to house batteries on driver side. There's two breakers on the front panel. One or both will trip when circuits overloaded. Check those breakers. Your BCC (main 12v fuse box) is in the same bay.
Xantrex Freedom 458 was standard equipment on Fleetwood DPs up to 2009. The updated Freedom 458 is still in production and is plug n play into your coach if you need a replacement.
