Encore 325SS generator
The Bartman
Have a 2021 Encore 325SS and the Generator overheats when parked. (works fine when moving down the road). Thoughts?
I don’t really know what to say on this. I guess I would look around the compartment for the generator and make sure there is good air flow around it. Look at the exhaust, does it have a clear run no leaks around the unit.
If it is over heating while sitting, it must not have good air flow around it.
Sorry I do not own an Encore.
Air cooled, water cooled?
Check the venting to make sure that something is not blocking the air flow. Check engine air filter and also if water cooled check to insure radiator is clear and full. Also check that the water pump and cooling fan is working.
