Exterior light bulb part number list needed
You can always remove the offending bulb and match it.
I pulled out the extension ladder and climbed to the top of the RV, pulled off the Amber cover and pulled out the small bulb. It was a 194. I think I’ll start a supply list to have on hand of bulb part numbers and fuses. I found a few cracked lens covers in the rear also. Might as well find out the bulb numbers for those too.
I’m definitely thinking about LEDs in the future. Do you have any ideas where I can get a replacement for the curved corner red rear lens?
There should be numbers somewhere on that lens.
Google it, but I'm sure it's likely been discontinued years ago.
The front upper amber cab light bulbs and the rear upper red clearance ones are a number 194 bulb which just presses in. The other rear taillight/turn signal/brake lights use 194 on the curved wrap around lens, and the 2 in the upper row use 1157 bulb which has 2 contacts on the bottom and the lower 2 lens use a 1156 bulb which has 1 contact on the bottom. Hope this helps others out their with an older Country Coach.
