Flat Towing a 2023 Gladiator
AllegroYall
Hey Friends , thinking of towing the 23' Gladiator above, behind my 2019 Open Road Allegro 32SA. Has anybody had experience with this model. Are there any problems or troubles I should be aware of ?
I have a Roadmaster Falcon tow bar and will be using a Roadmaster Direct Connect base plate system.
Haven't decided on the braking system yet , any thoughts or advice would appreciated.
Cheers
Cheers
Welcome aboard. I don't tow a Gladiator, just a 2 door Wrangler. I understand they are a little heavier than a regular Jeep but tother than that, it show tow just as easy as a Wrangler.
We have used a Brake Buddy since 2011. It is very easy to use but we have had to have the compressor rebuilt twice now. Having said that, we have been full time for the last eight years so it is used lots. Perhaps, for a user that does not, full time, the compressor might last longer.
Safe travels
We tow a 2020 Gladiator behind a 2021 Newmar Superstar (Freightliner M2-106 chassis.) It’s a great vehicle for a toad. Two things to be aware of that are more in the “points of interest “ category than actual problems:
1. The toad’s wiring setup will be different depending on whether the taillights are conventional or LED bulbs.
2. The Jeep is one of those vehicles that turns itself off/on at the stoplight. Jeep uses a second, smaller, auxiliary battery to power that wonderful “feature". If you start having issues, you can replace the main battery with a larger one, and disable the aux battery completely.
Safe travels
Thank you very much !
thank you very much !!
At over 5k, you'll definitely know it's back there. I tow ~6k with a similar powertrain, you just won't be hurrying anywhere.
Thx man , I am a bit concerned because at 5K , I'm maxed out on the receiver and towing capacity. Will probably stay with the Wrangler.
Technically speaking, your 5k towing capacity is arrived at as your gcvwr minus your gvwr ( most ~32' MH's with 5 or 6 spd. torqshift transmissions and V10 would be 23k gcvwr with an 18k gvwr thus the 5k tow capacity) So for example if your gcvwr is 23k and your gvw is 17k you can tow 6k, contingent on the appropriately rated receiver hitch.
Yes sir , the real limiting factor right now is the receiver. It 's only 5K , I'm going to replace that just for peace of mind. Thx!
Cheers
I tow a 2024. Gladiator With a 2019 Tiffin Phaeton 37 BH. No problems at all. I use the air braking system from the coach and the piston In the Gladiator. Make sure you hook up a charge wire When you set the system up to keep the battery charged in the gladiator or the braking lights will eat up the battery and you'll have to jump start it occasionally.
I used Eckhart welding to set up the tow system on the Jeep and all the wiring for the lights and battery.
If I am not mistaken your Gladiator is over 5K lbs. You Open Road 32 SA is a gasser with a Ford V10 engine. Your hitch is rated at 5K. I would upgrade the hitch if you are going to tow it.
That being said, the auxiliary braking system I use, is the Demco Airforce 1. You can get it for gas or air for DP's. I have used it on my two DP's and on my gas Tiffin 2021 32SA.
I towed a Jeep Sahara Wrangler 4 door with my 32 SA. It is almost 5K lbs, no problem at all. But you DO KNOW its back there climbing steep grades.
HH
HH
Thank you sir , I did upgrade the hitch but still a little worried about being maxed out on towing weight before putting anything in the Gladiator .
