Thanks, Rich. I heard that about the koni's and we're leaving that alone for now. The current plan is Sumo Springs and Safe-T-Plus bar in front and the Supersteer Trac Bar in the rear. Will let you know how that goes.You could start by weighing the coach with a typical load and you might find you can lower your tire pressure a bit. You can also load it up if you are running it with a light load. Think empty delivery truck vs a loaded one. But other than that you pretty much just have to live with it. I put Koni FSD shocks on my Bay Star and while they i proved handling a little, they also made the ride more severe and if I hadn’t sold it I would have put the originals back on. I’ve read that a lot of people install Sumo Springs and are happy with them but have no personal experience with them. Might be worth some research.
Thanks, Chargerman. That trac bar is on out list, too. So, how do you propose to reduce the engine noise? I'd be real interested in that!I just finished installing a complete Super Steer kit on my friends 2019 Bay Star. He then headed on a trip and he called me when they arrived. Both him and his wife are so impressed with the improvement in the ride. He says the swaying and porpoising have been greatly reducing. He said he was so comfortable that he caught himself speeding a few times. Next on the list will be engine noise reduction
I have used Dynamat in a couple classic performance cars with good results and would put the same material on the doghouse and also look at any area of the firewall and footwell area that I could add it to alsoThanks, Chargerman. That trac bar is on out list, too. So, how do you propose to reduce the engine noise? I'd be real interested in that!
