Alert Forum upgrade Sunday June 15th - [COMPLETED]
Staff member
RVF Administrator
I'm planning to perform a forum'ware upgrade on Sunday morning. The site will be down for an hour or so if all goes well, long if all doesn't go well :unsure: I'll follow up when complete.
This will be starting soon...
Forum upgrade is complete, however, I am checking various items post upgrade and only the default "camper" style has been updating. Other theme/style options will be updated shortly, some may be removed, some may be added, so for users using other than the default style you may be affected. Clicking "Style chooser" on the very bottom of the site is how you change styles if needed. Use default style should be your choice if in question but if nothing is wrong then leave it alone.
I'll report back when all checks completed. Resume use as desired.
For the most part all is good. There are a few items needing attention in the older styles and a few other areas that are not a concern for you, just some admin related issues. It will take time to sort this out as it's a major update behind the scenes.
Also of note, the "conversation" feature is now called Direct message, as some know it from older forums as private messages.
If you find an issue feel free to DM me, but my only concern is the main camper theme. Older themes/styles will either be updated or removed as I review the issues to see how complicated it will be to bring them up to date.
As mentioned in another thread, a new theme is in the works and will likely roll out this fall.
I moved this thread to the website feedback area so you can reply to it with any issues. Again, my only interest is the default (camper) style, no need to report issues on other available styles. I will review in time...
Thanks all!
