Gramps.busa
- Feb 16, 2021
- Tiffin
- 36LA
- Ford F53
- V10
- Jeep Rubicon
				I would agree, quality of most products have changed since the 90's when most/every mfr started to move their mfr ops to China. As far as I can tell the two AC units on our coach are original. The secret I think is running them. I have our coach plugged in beside our home and the AC units (at least the front one) are turned on and set to 78. When I run the genny monthly I turn both on, to load the genny for an hour.My old KS was sold with one original 16 yr old Penguin ll and one replacement that shouldn’t have been. This dumb owner thought there was a problem with it, and I am too embarrassed to say what really happened there. Nevertheless, those units were strong.
Dometic went through a period a few years ago that their quality suffered A LOT due to offshore, i.e., Chinese manufacturing. I’m led to believe that has been sorted out. Time will tell.
I second the Hughes Autoformer. I have the exact same one Neal does. When the voltage is low the Hughes Autoformer will boost the voltage up to 10% to keep it more stable. I have to think this will help my appliances last longer. I also have the plug-in digital voltage meter so I can watch the voltage in real time.Two things I use which may or may not help the life of my AC's:
1) Hughes Autoformer which is internally mounted next to my shore power reel and is always used. This can help stabilize the power as @TJ&LadyDi mentioned above. Campground power is terrible to say the least. My understanding is low voltage is the most harmful for your A/C.
Amazon.com: Hughes Autoformers RV220-50-SP, Voltage Booster with Surge Protection, 50 Amp: Automotive
Buy Hughes Autoformers RV220-50-SP, Voltage Booster with Surge Protection, 50 Amp: Power Inverters - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
2) I use Microair Easy Starts (soft start) which was put in for solar but some have mentioned there is an observation this is helping prolong the lifetime of RV air conditioners. (by carefuly buying knock-offs, only buy from Microair). Once I saw how great this working on my front A/C which is wired in to be used by solar, I added to my rear AC. Really helps when a 50 amp motorhome is on 30 amp power.
EasyStart Breeze RV AC Soft Starter for RV Air Conditioners
EasyStart Breeze technology reduces RV AC startup current by up to 75%, enabling RV owners to run their AC using a portable generator.www.microair.net
