Low water drain or tank drainWhen opening the low water drain next to the fresh water tank, the water barely comes out. The tank is full, so it should be coming out like a water hose. Haven't check for blockage in the line yet, but wondering if anyone has seen this and their fix?
Tank drainLow water drain or tank drain
That is why the question about type of drain.Make sure you open a few faucets inside to assure there is no negative pressure lock...
