Question Fresh water tank location
Rugman
Hello new to the forum. I will be heading out on a trip down I5 out west driving through the mountains in early March. Also new to RVing I have a 2018 sunseeker 2350le. Where is the fresh water tank located. I also have a heated tank switch what tanks does that heat. Thanks guys Rugman
As you check around your rv look for the opaque tank. That would be your fresh water tank. Your grey/black tanks are usually very dark to black.
Thanks, But do you happen to know if the freshwater tank is inside of the RV because I’m headed for cold weather
You're going to have to look. If you have a gravity fill, the water tank will be very close to that. They're often under dinette seats, lift up and look.
We had a 2014 forester - the tank heat switch was for the black and gray - basically to heat the black and gray enough to keep from freezing ( in theory, never used ours )
Our fresh water tank was in the wall just behind the gravity fill connection.
