TXheat
RVF VIP
- Jan 6, 2021
- Holiday Rambler
- Endeavor
- Roadmaster
- 350 Cummins
- None
- Yes
We recently acquired a holiday rambler endeavor 2003 model and the water pump functions but one of the wires was disconnected when plugged in it goes on, it doesn’t seem to be way to turn it off the low side 10 amp latching controller was also disconnected and the board seems like it may have suffered water damage so maybe that’s why the pump can’t be turned off? I should mention that all the switches that controlled pump are the kind that you push and they go back in a position not where it goes into a lower position and an upper position for on and off. I don’t know if that has any bearing?
As you can see in the photos, the connectors that go to the pump I plugged up, bypassing the freshwater tank connection. I tried to connect back the pump to the connections that are plugged up and there isn’t enough slack between the two pipes to connect it but I can’t figure out how else the pump is supposed to be connected. I’m including photos to help figure this out if anyone has the time. Thanks.
