TXheat
RVF VIP
- Jan 6, 2021
- Holiday Rambler
- Endeavor
- Roadmaster
- 350 Cummins
- None
- Yes
I kind of glossed over the part you said about choosing what is used inside the coach. Now you are talking about the specifics of the pump switches inside the coach? I’m not sure I follow.No! They both would work fine. Both use different fitting and bands. Your electronics likely got wet when someone found that out the hard way!!! Ultimately you will find out the same if you don't correct the issue!
That is why I mentioned the issue. So you can fix it now and save yourself trouble later. Has nothing to do with making the pump work!!! Choose the type that is used inside the coach and correct what has been patched .
both types and their respective tools are sold in my local home depot! May I suggest some YouTube videos on the differences of the two?
