Question Front lights
chinchey
I've looked everywhere, but can't find a solution to this...
I can't figure out how to turn off the lights on the front of my 2026 Coachmen Leprechaun.
I've tried the Cap Light switch just inside the entry and also the switch that is above the exterior mirror adjustment on the driver's door. As of now, I don't know what either of those switches do, but that's a question for another day.
I've also tried turning the headlight switch from Auto to OFF... no change.
They remain on whether I'm connected to shore power or running on just battery.
Any ideas?
Craig
If there is a Cap light switch my guess the switch is bad or wired incorrectly. The switch should control the light. It does on our Concord. Get to the wires on the switch with a volt meter and find the power source.
If you’re still under warranty contact the seller.
Good luck. Should be an easy fix.
I figured it had something to do with that switch. It's a new RV, so I'll let the dealership deal with it. The switch illuminates when I turn it On/Off, so I know it has power and works. I suspect that it's something more than just the switch.
Thanks!
Sounds like a couple of wires are in the wrong place on the switch.
I dont know much about the motorized units but my switch is in the compartment with the autolevel and wetbay
Yep. The switch is there.
I did some further troubleshooting (haven't had a chance to return it to the dealer, yet).
I disconnected the switch, tested the switch with my multimeter. The switch works as advertised.
I left the switch disconnected and turned on the battery. My lights came on... without the switch in the system.
So, I know it's an issue above my pay grade to fix.
