redbaron
Moderator
- Nov 3, 2019
- London Aire 4551
- Spartan
- 2020 Jeep Wrangler Unlimited Rubicon
I am camping in 74F outside temperatures with 88% humidity. I decided to try the dry mode on the furion AC, and I am very impressed.
With a dometic system, I would have to turn the AC temp down very low in order to dry the air. Furion takes a different approach with Dry mode. It will run the fan on high to bring the rv to temp,and then switch the fan to low speed constant on, while cycling the thermostat on a timer of 6 minutes on, 6 minutes off. The Temps will drop lower than desired initially, but will start to level after an hour or so.
Judging by the river of water running off the roof, the function is working as described.
