Furrion Artic 10.6 12v fridge setting...
Phillbo
RVF VIP
Anyone familiar with this model? I need to get more air flow into the fridge from the freezer. The knob in the freezer is simply called "freezer control" and has setting from Colder to Coldest... pretty effing vague. Trying to figure out which direction to turn it to open the vents to the fridge section more....
Does Coldest close off the vents and retain all air in the freezer or open them to flow more air to the refrigerator section???
Does Colder mean the freezer will get colder but not the coldest because the vents open more???
The primary control is in the fridge section and has setting from 1-5 with 5 being the setting that makes everything coldest... so confusing. Who lables this crap ;)
Manual is useless... maybe s call to Lippert?
Anyone?
My temperature adjustment experience with various rv fridges is similar. Since what we most care about is compartment temperature, I bought a laser thermometer and will just "read" the actual temperature in there. The Norcold compressor/freon fridge in our OVR has 1 to 5 setting, individually, for both top and bottom.
Will have to go look, but would not expect to find variable position airflow control vanes or doors in the Norcold. Got me wondering now if Norcold is flowrate regulating two freon loops to get that accomplished, or doing something else.
Straight over my bald ass head.
I'm just trying to figure out if I will impact the fridge section with a twist of the knob in the freezer or if the fridge is only controlled by the buttons in the fridge area.......
Per instruction manual Section 1.1 "Temperature Setting" the fridge compartment temp is controlled by the front panel buttons, while the freezer temp is controlled separately by the knob in the back of the freezer compartment.
Try to stay away from accidentally button-setting it to Eco mode ,which can happen as you cycle thru the control choices by button pressing.
Here is a link to the instructions:
