Fuse 6 (audio/video/radio) keeps blowing- short?
Windsport M29 Owner
My Thor Windsport M29 audio/video/radio fuse keeps blowing. It worked while driving to our campsite. Then when leaving it did not work. I checked the fuse (#6) near the bed and it was blow. When I turn the house power off, then replace the fuse and turn the power back on, the fuse pops immediately. There must be a short somewhere. Where do the wires go? One end is under the dash and the other must work it's way back to the fuse box. The slide was out and then in. Possibly a wire got shorted while moving the slide. Where should I start looking? That's a long distance and the harness is not easily accessible. Are there any connectors to check along the way to look for a short?
Looks like you're on the right path! Check for pinch points on the slide first,then ware on the harness.
