Our Wraith, and likely most Nexus (and many other rv’s) came from the factory with a quick connect LP hose. I was really happy about it because I hate using portable propane tanks and almost dislike propane exchange just as much. I didn’t want to deal with either. On our first outing I found this setup didn't work. I assumed the regulated LP at the quick connect didn’t have enough pressure to then be plugged into another regulator.
After some experimenting I found that it would work if I tee’d off before the regulator on the RV (direct pressure from the LP tank.) I didn’t like that setup for multiple reasons. First and foremost there was high pressure LP on the hose and quick coupler. If either failed it would be a problem and the high pressure was more likely to cause a failure. In addition, unplugging it under pressure resulted in so much LP leakage that there was liquid LP coming out of the grill side hose.
Many posts recommend eliminating the regulator from the grill/appliance. That would of course work, but, at least in my case, removing the built in regulator on our Weber Traveller grill wasn’t straight forward. Plus, if I did that, running portable propane tanks would no longer be an option in case of emergency.
What I came up with is this…
I put a tee in the line before the RV regulator. I then put a 1st stage regulator at the tee and then installed the quick coupler on the output of the 1st stage regulator. From there I connect the hose to my grill regulator and quick connect.
The 1st stage regulator drops the pressure to around 30psi which I am comfortable with. I don’t know what the pressure of the LP tank is before regulation, but I can say that unplugging it now doesn’t produce liquid LP like before. You can also tell it is much lower pressure than before.
It will be next year before I can run this setup extensively to be sure it works reliably. It did work nicely in my testing though.
