Gas Water Heater
mowerman
I have a 2019 Coachman Catalina Legacy Edition. I have electric and gas hot water heater. The electric part works fine. The gas part doesn't. I have gas to my stove and fridge. I purged the lines. Turn the switch on inside and it turns red like it is suppose too. Do not see or hear the igniter at all. I did clean the probes of soot which was hardly any at all. Any ideas? The fuses inside in the panel at floor level was all good. Breakers was good.
We had a similar problem this past summer. It turned out to be the Ignition Control Module. It also could be your Thermal Cut Off Fuse. If it's in a Coachman it's most likely an Attwood / Dometic water heater. Google "repairing an Attwood RV water heater" and you will come across a whole bunch of really helpful You Tube self help videos on how to trouble shoot and repair the water heater.
