I have an Onan 5500 generator on my toy hauler and it starts fine at my home which is 2200 feet in elevation, but at 8000 feet in elevation when I go to the mountains I have to remove the air filter and hold the butterfly valve in the carburetor open to get it to start. Once it runs a few minutes I can put it back together and it will run
I know there is an elevation adjustment on the generator. I also discovered that the plastic knob around the vale stem just turns freely and does not turn the valve itself. So, in order to make it start at the higher elevations I should be able to slip the knob off and turn the valve with pliers. But do I turn it clockwise or counterclockwise and should it require one half turn or two full turns or whatever?
