Grand Design Imagine XLS or Alliance Delta - is half ton truck good enough?
JasonC
Hello everyone!
I have been thinking about getting a truck and travel trailer for years. I have never owned either, so a complete newbie. After some research online and talking to RV dealers, I'm think about the following options for the trailer:
Grand Design
Imagine XLS
23LDE
Dry Hitch Weight 621
Gross Dry Weight 5,831
Gross Vehicle Weight (GVWR) 6,995
Exterior Length (w / hitch) 28'5"
Alliance
Delta
252RL
Dry Hitch Weight 687
Gross Dry Weight 6545
Gross Vehicle Weight (GVWR) 8450
Exterior Length (w / hitch) 29'11"
Both Grand Design and Alliance literature say that these models (28-30ft long) are specifically designed to be towable by half ton trucks. With a truck like Ford F-150 V8 with "Max Tow" package (axle ratio 3.73), the numbers seem to suggest that they could well be. But some online reviewers say that even the properly equipped half ton truck shouldn't be towing trailers more than 6000lbs GVWR. So I am quite confused about this. If/when I get the trailer, I plan to go to mountainous areas like Colorado and Utah. Would this set up struggle to get uphill? would it be safe (to control) going downhill? Would a 3/4 ton truck like F-250 be an overkill?
What are the real world experiences of people towing trailers in that weight range with a half ton truck?
If I get either of those trailer, and get a half ton truck, would I always be wanting an upgrade to a 3/4 ton truck?
I would really appreciate your input and advice.
Thanks,
Jason
I have a Grand Design Imagine 2800BH towed with an older Toyota Tundra 5.7. It is within the specs with a 15% safety margin for the actual weight. It tows very well. A few things we did to make this safer was use the weight distribution hitch, ensure the trailer weight on the hitch was proper and not over the limits. This involved several loading and reloading attempts to get the distribution to a satisfactory point.
We also upgraded the factory brakes on the trailer and truck, and finally slowed the overall speed to 60 for an average while driving.
We have pulled this all over the Rockies, from Texas to Western Montana and oregon, with no problems. Slow climbing and drinks the fuel, but as far as safety, no issues.
Just pay attention to actual weights and keep yourself at least 10% under. I was aiming for 20% under, but couldn't get there and arrived at 15%.
You will get a lot of opinions on this subject. There are no bright lines except the manufacturer towing specifications.
As a general rule folks towing mid sized trailers have the best experience if the towable does not exceed the weight of the tow vehicle by significant amount.
I tow a 7,300 lb GW Airstream with a 7,300 lb GW F-150 PowerBoost HEV. This combination is very well matched with a B&W Continuum weight distribution hitch.
I have no experience with the trailers you listed but the second trailer with an 8,450 lbs GW and 30' in length is really getting into F-250 territory, in my opinion.
Both of the trailers you listed are high profile, slab sided trailers with poor aerodynamics that put extra demand on any tow vehicle.
thank you very much for sharing your experience! numbers on paper/screen are one thing, I've learned that real world applications are often quite another. 2800BH has a GVWR of 10,195, that's almost 3000lbs more than the model I'm looking at. that's a very good reference.
it's really good to know that "the towable does not exceed the weight of the tow vehicle by significant amount" as a general rule. Your "7,300 lb GW Airstream with a 7,300 lb GW F-150 PowerBoost HEV" is also a very good reference for me.
I'll keep in mind that "8,450 lbs GW and 30' in length is really getting into F-250 territory" - that may sway me toward the lighter GD model in my choice, as these two are very similar otherwise.
thank you!
Hello everyone!
Grand Design
Imagine XLS
23LDE
Alliance
Delta
252RL
Thanks,
Jason
The GD would be about the biggest I'd want to go with a half ton. Our trailer is about 6 inches shorter and 300 pounds lighter on the dry weight and I suspect I should be in a heavy duty truck, though I also have 3 kids, a dog and a wife who likes to over pack.
Thanks for your reply, that's a very good reference too.
so far what I am getting is, while a trailer with a GVWR around 7000lbs could be safely towed by a half ton truck, and many people do, it's close to the max capacity of the truck?
That is a good take away.
The truck we are using is a 2011 Tundra with 4 doors and 5.7. We added about 600lbs of weight in the bed, 2 passengers, and weighed the combined loaded to get the front axle , rear axle weights to ensure the truck itself had plenty of excess weight available. The trailer itself wasn’t the issue, as we exceeded 20% safety margin on trailer weight, but the trucks weight distribution and per axle are what brought us overall to 15% safety margin.
I wouldn’t feel comfortable with less than 10% margin.
This summer the trucks brakes gave out while in the mountains of New Mexico. The front brake pads disintegrated and left only metal on metal up front with rear brakes and trailer brakes doing all the work.
Luckily there was a repair shop nearby and all 4 rotors and pads got replaced on truck. I hate to think what would happen if this was over weighted.
Most likely, though you'd have to weigh your specific truck and trailer and compare that to the specs on the truck to be sure.
I have heard some folks recommend buying the trailer you want first then figuring out how much truck you need to safely tow it. Not sure how feasible that is in real life, though.
Payload will typically be your limiting factor, more so than towing capacity. Note that trailer manufacturers tend to understate the dry tongue weight of their trailers while truck manufacturers tend to overstate the payload capacity of their trucks.
Happy shopping. You have some good advice, I’ll leave it right there. I will add, get the RV inspected ( new and used). Even new rigs leave a lot undone. I did not on the only new rigs we purchased. I wish we had. It took a while but all things were made right.
Welcome to the group.
Personally, I wouldn't haul either of those trailers with a 1/2 ton truck. IMO 7000#'s + added cargo weight, no question I'd be looking at 3/4 ton trucks. The only question would be diesel or gas.
Be aware mfg'er tow ratings are extremely exaggerated. For example, our truck is an F150 Fx4 EcoBoost with Max Tow package. It is rated to pull 11,000# with a max hitch weight of 1100#. No way I'd every attempt to pull something that heavy. I've owned enough trucks and pulled enough trailers to know half of that is a realistic number. Since we knew we were looking at trailers under 5500, we went ahead with it.
We settled on Grand Design. The decision was between an MLE and MKE. We ended up buying an XLS 17MKE and are so glad we did. IMO it is the perfect couples trailer. There is no wasted space with a bed or dining table.
It is well withing the specs for my truck, and it hauls it very well. That said, I have not yet been in the mountains with it. That test is yet to come.
Bottom line, IMO you can never go wrong going big. The difference in price to jump to a 3/4 ton is significant, but also opens up more possibilities in a trailer.
You’re not wrong. I would be looking at F250 with the 7.3 gas. We have the 7.3 in our Concord and it is strong.
It is different it not towing every day.
Lacking experience, you may have missed some important takeaways.
20% is a real number in engineering calculations. They are based on duty cycle, not just capacity. Capable does not always take life cycle into account.
So the question to ask is how often will I tow? How long will I plan to keep the truck?
Will I exceed GCVWR when I have put bodies and equipment in the truck? This number needs to include the hitch you put on the truck.
In my world I pull a variety of trailers. An 8700# fifth wheel. A 7500# GVWR cargo trailer. And a teardrop.
My truck? RAM1500 5.7L 8speed tyranny. The fifth wheel pushes stock springs, but HD springs remedy that issue. With141,000 miles, I lean towards the opinion of good fit.
Why 1500 rather than 2500? The truck is my daily driver, where 4mpg difference can be significant.
In my book first? 80% capacity. Second? Durability. Third? Economy when scaled.
Hope this helps.
thanks for the tip, 3rd party inspection for sure.
thanks, as I am also thinking about the XLS models, that's very helpful reference. yes, the price difference between half ton and 3/4 ton is the main reason for thinking about towing with 1/2 ton.
