Help locating slideout locker arm sensors
GreenHornet
I've got a 2008 All Star with a single slide. I went to slide it out today and the latches unlocked but the slide won't move. I have the Intellitec slide out controller w/voice. I've read various threads and learned that I can (carefully) move the slide by jumpering + and - to pins 7 and 8. This works. I'm hesitant to take the slide all the way out or in this way because I'm worried the motor won't stop and I'll do damage. What should I check next to get the slide to work from the switch? I do hear the "slide out arms are unlocking" message when I press the switch. I've also verified power (again from other threads). I've let the gen run for 30 minutes and I'm well over 13v but still no joy.
After some further troubleshooting I think I have a clue. My helper operated the switch while I watched the control board. I can see that La1 and SO lights are off and La2 is on. According to the manual, the board thinks La1 is locked. LED is off in the lock position and ON in the unlock (closed switch) position (I visually confirmed that it's not). The slide is about 8 inches out and the latches are fully retracted. Where should I search for or reset the locker arm 2 sensor?
