Hi from Fl 🌴 In need of furnace advice. 2016 Starcraft Autumn ridge furnace help.
RVlivingPG
Florida
Starcraft
Autumn Ridge
Yes
The furnace ignites, run about 7 seconds then shuts off. Lp gage goes to red when furnace kicks on. Tank is full. No heat..and it's getting cold at night here. All help appreciated.
I would contact a mobile tech to investigate. LP guage jumping like that doesnt sound normal and dealing with propane system if your not experienced with it could be dangerous. No matter where your at in FL there should be a mobile tech available. We use small electric heaters to suplement when needed, assuming you have electric hooks ups where you are they could get you by until a repair is made to furnace.
Those are the safety features built into the furnace. Lots of You Tube videos are available to explain what's going on. Likely related to a no spark condition or an insufficient amount of blower air to close the "sail" switch.
Rick
Thank you. We fixed it ! He cleaned the exhaust vent and it had more mud dauber nest.
Fixed ! Hubby cleaned out the exhaust again and found another mud dauber nest. Putting screen over it soon.
