How long do you leave water in your fresh water tank?
Y'all remember drinking out of the garden hose? There are thoughts that allowing "some" impurities into your body strengthens one's immune system. I'm still a little finicky in that regard.
Yup, I remember. I don't much care what is there by nature. Rather I am more concerned about what is put there by the water processors. Remember the largest organ of your body is the skin, so the poisons they put in the water are consumed via the skin.
My opinion is mostly dismissed here, guess people don't think I do my due diligence! What I suggest is you pull up the material data sheets for the chemicals you know are put in the water and learn the filters you need to use to make your water safe. Then quit worrying about what is in the water naturally.
What you are going to find, is you need to read the labels just to make sure they didn't add these harmful chemicals to your bottled water.
Have a wonderful day and do your research before your bone density tests prove to you what I am telling you!
We have been very happy with the testing results to remove some of the man made chemicals in a house installed system using filters from Enpress:
Wish we could have these filters in the RV. In the RV we use a dual filter big blue style system with the final filter at 1 micron - it does restrict flow a bit but when there isn’t enough pressure we just let it slowly fill the fresh water tank and then use the fresh water tank as our source.
I didn't see bone char filters on their site. That's the filter most needed for bone density issues.
That was brought up before. It was the result of using non-sterile water in a Net-poti; directly against the instructions and cautions with nasal rinses.
