- Nov 3, 2019
- London Aire 4551
- Spartan
- 2020 Jeep Wrangler Unlimited Rubicon
The circuit is rated 50 amps at 240v, which is the same thing as 100amps at 120v. Line 1 & Line 2 are each 120v.Explain the 80 amps. The circuit is rated at 50 amps. The total available amperage to the panel is 50 amps whether it is line one or two. If you exceed the 50 amps the main should trip.
Each breaker can supply 120v @ 50amps. When used as 120v appliances, you get 100amps at 120v, or 12,000 watts of power.
That is why a 12.5Kw generator is required to power the RV the same as when connected to shore.
If you are using a 30amp plug, then you only have 3,600 watts of power available.
A single 50 amp, 120v Line will be 6000 watts of power.
