Question How often check fluid levels?
Joe Hogan
Florida
Dutch Star 4311
Cummins
2018 Ford Flex
Since the DSDP likes to mark its territory I have gotten in the habit of regularly checking fluids.
Surprised by the attendant at Cummins thinking using 2 gallons of coolant per year was minimal and “normal”!
Until the DSDP stops marking where it is stopped longer than a day or so I’ll keep at it.
How often do you check fluids? Engine Oil, transmission, coolant, Oasis, etc,?
You may have a cold temp leak. Find the source of coolant and look for any joints. Often a 1/4 turn is all that’s necessary. Once warm these go away.
Trucks and commercial drivers don’t worry about this as they aren’t stopped long enough. We are a different crowd.
Pretty much any time before a travel day. This also helps you learn what is changing and how much of a change is normal.
Bill
Checking the concrete when at or leaving your site is a good way to see if you have a leak. This is how when in Angel Fire on their white concrete pads I new I had two problems. 1) Water leak which turned out to be the shower drain 2) Oil dripping, later turned out to be a head gasket. Otherwise you shouldn't see any leaks.
I usually check the day after stopping unless a one night stop. This allows me to identify a potential problem before next departure. I have no leaks and hope it stays that way
