How to manually operate slide out on Pursuit.
jimtree
I have a 2014 pursuit, 32/MH. The couch/dinette slide appears to have no power to slide out. I attempted to manually slide it out but it only goes about two inches. Then refuses to budge. Am I missing something? Oddly enough, it will retract by using the control button.
Check your DC voltage under a load. These motors draw lots of amps and you should be plugged into shore power or a generator to have maximum power available.
Is it a Schwintek?
Try this if you need help. rvtaa.org › technician locator
On my 2017 there was a sequence of buttons on the controlleer that would overide the switch inside and retract or extend the slide. Controller on mine was on the roof of the wet bay. Not sure where yours may be, hopefully someone with your make/model/year can chime in. You could also try googling slide controller for your make model year and see what comes up. Sorry, Pursuit slides are a pain in the butt in my limited experience.
