Tip How to QUOTE text
There are multiple cool ways of quoting text in this forum'ware whether another post or something you paste in from the outside.
  1. If you highlight text from another post a small button will appear on the lower right to either reply (which will quote that selected text) or add to multiple quotes
  2. Simply replying to a post should quote the post replying to
  3. On the editor that you use to create your post or reply is a "..." button with a down arrow. In that drop down is a QUOTE option. You can select the text you wrote in a reply editor and then with it highlighted click the quote option in that drop down, or click that quote option first and type your reply between the quote tags.
A lot of options to you for quoting text you want to have a discussion about.
FYI
  • Like
Reactions: Jim
