Question Hydraulic slide out
Diesel Dave
Slide out will not move in or out. Checked power going solenoid it has power light bright on tester, however as soon as you press the switch the light goes out on the light on the tester and slowly gets bright again. Could that be a battery problem, solenoid or relay problem?
What is the battery voltage?
HWH hydraulic systems tend to be sensitive to voltage. We learned that if the HWH doesn’t want to work, we put a battery charger on for 10 min and try again.
