Hydrolic jacks
Duttydog
Hi I hope someone can help, I've got a Thor Windsport 2005 and for some reason two out of four jacks keep retracting not all the way but 3 to 6 inches off the floor
Try extending them, then go under clean the shafts and spray them with silicon, new grease wouldn't hurt either. Then cycle them a time or two.
It's recommended to use a dry lube as dirt and grime will stick other lubricants.
Check your hydraulic fluid tank.
