In seaview Washington.
clarkkudlacekkim
It's raining like crazy my bedroom floor is getting wet and I'm trying to figure out if the rubber slides are suspossed to curl in or out and if that's where the waters getting in the trailer at
It's definally coming in from the slide I just don't know how
When your slide goes out the rubber seals should go out.
We have a Winnebago and the W/Strip curls in on ours. We had a small wet spot near our bedroom slide last year and I discovered that water was seeping into a molding at the bottom of the side wall of the slide. It is held on with about four philips screws. I removed it then ran a bit of silicone where it ended and then after it was reinstalled, another bead along the top edge. I also noted that the side and bottom W/Strips no longer met tightly (our coach is 13 years old now so they probably shrunk a bit). I ran a bead of silicone between them so the gap was filled. That cured my problem.
Good luck
Darrell
Every RV I've owned with a slide, leaked water when it rained hardon the side where the slide was. Especially when the wind was driving the rain. I just put the slide in Problem solved.
