Inverter
ynot
tiffin
32sa open road
ford
ford
hello all ,i am new to to the group ,2018 tiffin allegro open road.32sa very pleased with ,
noticed few days ago that i had no power to my fridge or the 110 Gfis ,while on the road.
everything works when i plug to power. any advice ?
Use a multimeter set to DC volts to see if you do or don't have power to the input side of the inverter. If no power to the input, move "upstream" on that circuit to find the fault.
Rick
Hello and Welcome to RVforums from Ely, Iowa. I am basing this on my rig which is older. Go to the inverter and see if the breakers on the inverter are tripped. this happens to mine occasionally. When I switched my fridge to a residential I put in a dedicated outlet for it.
If you have a control panel that controls the inverter, charge settings, etc. make sure the Inverter is in fact ON. On mine there is a green light next to Inverter indicating it's enabled.
thx Neal
i tried the generator it run but still don't have power to fridge and GFIs .
Either your inverter is not enabled (on) or there is a problem with it such as the breaker needs to be reset. Do you know what Inverter you have? Model #? How do you control it? Is there a control panel that allows you to turn it on/off from within your coach?
Thx
It’s a go power IC2000 with 3 solar panels
