Itasca Suncruiser 2004 electrical issue
Gus R Bus
Mesa,Az
Itasca
Suncruiser
Workhorse
GM
Jeep
Yes
We are experienced full timers in our 2004 Suncruiser. We lost power to 5 outlets from kitchen to bath so we figured the GFCI went out. After replacing it, we still have no power. All breakers are good. Anyone have any ideas?
Are outlets on a slide side?
No. Two of the outlets are outside. I'm wondering if the he elements got to one of those.
Seems they run through the wall. Hadn't thought if a rodent. But we have been in it for months and so have a dog.
Start with farthest non working outlet work back to box. Loose connection somewhere.
The GFI has a load side and a source side, I have done them wrong. Just saying.
Electrical outlets are "Daisy chained". In other words when one stops work, those beyond it stop.working too. Usually it's a loose wire, bad outlets, or bad ground. Buy a $5 plug in tester at Home Depot. Start with the GFI WORKING DOWN THE LINE. Don't forget the outside outlet(s). If it's a bad outlet, replace with household type. Use screws to tighten wire rather than push in. Hope this helps.
