Jayco vs Grand Design
Thank you for sharing the link.. Which the Jayco has double sided Azdel vs that GD doesn't.. They are still using luan but brag about a 400PSI pull test on the sidewalls as their reason to not use Azdel.. I take it you favor Jayco?
I thought I heard that Jayco quality went downhill in about 2018 but I also heard GD quality went downhill in 2020-2021 so maybe it's moot at this point.
Take a look at this article.
.40
What ever it's made of consider a tow vehicle larger than 1/2 ton to pull it,if using it across the county.
I thought Azdel was much safer for the enviroment since its basically a fiberglass and Resin composite?
Fiberglass and PP!
Point is moot! Let's just say quality hasn't got any better in any RV.
