Welcome to RVF, @Tracyi; glad you joined us here. Not familiar with your specific model, but the water pump on most RVs is usually located in close proximity to the fresh water tank filler. One way to pinpoint the location is to have someone inside operate the water pump (turn on faucet, etc.) while you listen for the sound of the pump. That should get you close. Access to the pump will probably be via a nearby storage compartment.
Traci, if it is anything like mine, on the left side (driver's side) of the pass thru is a panel that hides the water pump. When I get back to a computer I may have better info for you.
edit: Got back to my computer and didn't find anything else on it. You can try running the pump then listen in your pass thru for it. It's probably real close to where your water hook ups are.
