Resolved Kitchen top slide seal
AbdRahim
BayStar 3626
37’
Ford
V10
None
Went to lubricate the slide seals and found the seal is pulling off in the center. I have been unable to get it secured. Anyone else have this problem or know how to fix this?
Well., I cannot believe no one has been too aggressive in cleaning under that seal and pulled it off the track. So, perhaps I can say you heard it here first folks.
Anyhow, I think I got it back on. If one sticks one’s finger all the way to the back while holding the attached section in place, one can feel the groove in the seal that slides onto the metal. It takes some stretching to slip it back on, but I think it is done. We will see if it stays on through multiple slide cycles.
Those bulb seals have metal in them that fits tight when slid on motorhome. If it came off in the middle there is a chance the metal rusted letting it to slide off. Keep eye to see if it comes down again. without a slide topper it's not that difficult to change yourself.
Thanks. I think I pulled too hard while trying to cle underneath it. Although, I did not feel metal. It seemed like I just stretched the rubber back on to the metal flange. That was enough of a chore. The instructions say don’t cut it at the corner. It looks like even Newmar cut it at one corner. I will have to check it again.
I had 1 noticed hanging down. I was at Newmar service for some work when i noticed it. The middle was rusted, perfect timing. I just had them fix it. They took the topper off and layed back on roof. I helped my brother change his. Didn't have a slide topper, was pretty easy.
I'm actually in the process of doing this with all three of my slide room seals. It's pretty straight forward. 2 of mine also pulled off the flange. I removed the slide toppers (also getting replaced) and forced the existing seals back up on that flange. Mind did have this little metal barbs in them. I don't know if they're original. The RV is a 2003, so quite possibly. Water got in that rubber channel and those little barbs rusted. Then they disintegrated in spots. Other areas it's nearly impossible to pull off the flange. So I'm redoing all of them.
I've cleaned everything and now waiting on the new rubbers. The replacements can be found at uni-grip.com. Mine are part number ED-50470. Yours may differ.
