Leveler
Getting a Jayco Class C. Do I need to put a leveler under both rear tires. Or just one tire.
I'm guessing a little here. I think you mean "adding a block" under your "dual" rear tires to level the unit, should you use a block that will fit under both tires or is it okay to just lift using the outer dual. If this is correct, then my opinion is: "Ideally you would make sure the weight of your motor home would be spread over both tires just because it will be safer and kinder to the outside dual". I don't think it is a hard fast rule though. You can suit yourself.
Darrell
