leveling and slideout sequence
KYMEDIC
I have a 2023 Dynamax DX3 and I have an issue that something that I may just have to live with. You have to extend then slides BEFORE you can level the unit. I have talked to Dynamax and they just tell me thats the way they designed it. From all that I have read this is the only unit that has told me to put slides out first.
well, because you have to have the ignition switch on for the slides to work, you have to put the slides out because if you level first,
when you attempt to put slides out, then the jacks automatically retract. Is there a "fix" for this?
Maybe I'm missing something. Their (Dynamax) advise was to extend the slides FIRST which is contrary to every other manufacturers advise as it increases the chance of a slide becoming misaligned due to being uneven if you are on a camping site that's not level. Almost all if not all recommend you level your unit BEFORE extending the slide outs.
My coach manual instructs to extend then level, so that's the way I do it.
I follow my manual as well, despite the order being changed in retrospect.
Yeah, check the manual.
Our Forester we had to level before the slide per the manual.
Our Newmar has us check reveal around slides, put out slides while still at ride height, then do the leveling with the jacks.
