Leveling fault
Markj1888
Hello I have a 2010 American Eagle. On our last trip one of the hydraulic lines blew for the leveling system. I have replaced the line and refilled the reservoir but currently have a fault in the system that won’t clear and won’t allow me to move the jacks. I researched a little and found out how to read the fault code on the Valid control panel which ended up being a hydraulic pump timeout fault. I guess the system is designed to do this if the pump runs for more than 90 seconds. I cannot find anywhere how to get this fault to go away. I have reset the control panel, I have turned off all the battery’s and try to reset that way but still no luck. Does anybody have any advise or experience with this situation. Thank you for any hep
I would say air in the line is the cause. Bleed the system.
