J&JD
- Nov 3, 2019
- Fremont, California
- Dutch Star 4018
- 40’
- Freightliner
- Cummins ISL450
- Jeep Wrangler Sahara
Certainly not but if you simply shut down & walk away some of the air bags will slowly leak until the coach settles on the frame. If you’re lucky and have a leak free air system then it will stay at ride height. It doesn’t really matter for storage purposes unless you want to operate the slides. In my case, with the coach parked in the backyard, my right front airs down in about 3 days. Sometimes I leave it that way for weeks with no problems and everything in the coach works just fine except the slides. If I want to operate the slides I start up the coach and let it return to ride height which is where Newmar recommends the coach to be for slide operation. Bottom line, IMHO, store it any way you want, just be careful with slide operation. And, I have a residential refer which doesn’t seem to matter being a bit out of level.Is it actually a necessity to store a motor home level if all the systems are turned off anyway?
