LightShip Systems Review - Aerodynamic Enhancement System
turbopilot
Prescott, AZ
LightShip
AE.1 Cosmos
Electric
2025 Ford F-150 PowerBoost HEV
LightShip Systems Review - Introduction
The LightShip brings a whole new set of technologies to the recreational vehicle market. The LightShip technology draws highly from the automotive industry and specifically the electric vehicles produced by the world’s manufacturers. The company was started by founders whose roots were in EV vehicles (Tesla). So much of the technology in the LightShip is new to the recreational vehicle industry. Things like large lithium batteries, electric drive motors , high voltage HVAC systems and a vehicle built with CANBUS controllers is not found in any other legacy recreational vehicles. But most this technology is hidden, under the floor or up front under the AeroHub shroud, of the LightShip. As a result the potential customer cannot appreciate the difference between a Lightship and a legacy RV on the market today simply by casual tours of the cabin.
In this thread and a series of future threads to follow I will try to detail what I have learned about “what is under the hood” in a LightShip system by system. This information was gathered by several trips to the factory, following the assembly of my LightShip and several factory tour videos published on YouTube. Through it all LightShip has helped me learn about their technology and very patient with all of my questions. However, this is just the beginning to understand how the LightShip works since so much of the functionality of this RV is in the firmware that ties all of these systems together. In the coming months it is my hope to add to the individual system threads to follow with much more detail about how all of these systems work and more importantly work together. So this series is about the hardware. Hopefully we can someday learn about the hardware that makes it all work together.
I have also been talking to @Rory (Lightship Team) about producing some video presentations by each of the engineers leading the various LightShip systems to get further details about these systems. I have been around recreational vehicles my whole life but very little of the knowledge about RV's learned in that time applies to the LightShip. This is a new to the world product with a steep learning curve. I will be posting future threads about most of the other LightShip systems. Here are some of the systems I am thinking about. If there are other systems you think should be reviewed leave a post.
  1. 12 volt Electrical System
  2. 48 volt Electrical System
  3. 120 volt Electrical System
  4. 240 volt Electrical System
  5. 400 volt Electrical System
  6. 1.8 kW Integrated rooftop solar System
  7. HVAC System
  8. Trek Drive System
  9. CANBUS Distributed Network Body Controller System
  10. Telematics System
  11. Vehicle Leveling System
  12. Fresh Water System
  13. Hot water System
  14. ATLAS Tablet Application System
  15. Tow Vehicle System Integration with the LightShip
The first system to review is the Aerodynamic Enhancement System. This is a foundational system in the LightShip. More than any other system it transforms the look, feel and functionality of the vehicle. At its heart this system performs a very simple task: it reduces frontal area (area exposed to the wind) by 40% that in turn leads to at least a 30% reduction in aerodynamic drag compared to other towable RV’s. That 30% reduction in drag represents most of the resistance to towing a trailer at highway speeds, since rolling friction and weight is a very small part of the towing load at highway speeds.
That 30% reduction in drag leads to a 30% reduction in energy cost per mile while towing and a 30% increase in range of the tow vehicle. That same 30% reduction in drag applies to all types of tow vehicles: EV’s, PHEV’s, HEV’s, EREV’s and all pure ICE vehicles. With the 30% reduction in drag the 77 kWh battery packs have enough energy to offset the drag and rolling friction of the LightShip for 300 miles. If the canopy did not retract It would require at least one more 600 lb battery pack (total of three packs) to propel the trailer at highway speeds for 300 miles. So the added cost and weight of an additional battery pack is offset by the added complexity of retracting the canopy.
For ICE and HEV tow vehicles with good towing range to start the 30% increase in towing range and efficiency supplied aerodynamics alone will probably displace the TrekDrive system to an "on demand" assist device hopefully available in future firmware updates. Given the current state of EV tow vehicle technology using the TrekDrive system full time to gain enough range to compete with other tow vehicle types.
The development of the LightShip aerodynamic system is explained in detail in this 8 minute video segment by Ben Parker during a factory tour beginning at the 20:00 minute point in the video. Listen carefully to this 8 minute segment as it succinctly defines the compelling case in recreational vehicles to improve aerodynamics.
The aerodynamic system is composed to two parts: the over all aerodynamic shape of the canopy, AeroHub and tub of the LightShip and the ability to retract the canopy by translating it three feet down where is covers most of the lower tub structure in "Drive Mode". This translation happens using four, 48 volt, computer controlled lift actuators. These actuators are in no way comparable to the cheap and dumb Lippert 12 volt slide wall actuators well known to the experienced RV owners. The LightShip actuators are 48 volt (see 48 volt electrical system discussion) and are controlled by one of the LightShip body controller modules (see CANBUS Body Controller System). RPM and torque are sensed in each actuator motor to smoothly raise iand lower the canopy. There is logic watching these parameters in the motors to keep them synchronized. Should one actuator fail the logic will take it off line and the other 3 actuators have the capacity to complete the translation up or down. So unlike actuators found in other legacy RV's these devices are smart and strong.
In the case of total electrical failure each lift actuator has a fitting at the base of the jack screw to manually extend or retract the canopy. This back up procedure is detailed in the LightShip Owner’s Manual. Here are the locations for the manual actuator extension connections.
There is a weather proofing seal that runs around the 360 degree circumference of the canopy to keep the interior sealed from external air in the up and down position.
For more information about the LightShip Aerodynamic System see this Lightship Journal story:
Designed From the Ground Up for Efficiency: The Lightship L1 Aerodynamics
If you have any further questions post them in a reply to this thread. I am sure Rory will correct any information I got wrong and answer further questions about this topic.
Great read @turbopilot ... you still on track to getting yours before New Year. Very much looking forward to your first impressions. I don't have any major suggestions to add to your review outline, a small request that when you review each system, you close each systems segment with reference to how it is managed/monitored using the Atlas controller, so by the time you get to "13" we'll have a comprehensive understanding of the parts and the whole.
Thanks @josephpRV. Heard from @Rory (Lightship Team) last week, the build will be done this year but the Q&A team wants to spend some time with the unit which is fine for me. Never bought an RV where the Q&A process held it up. :) So maybe early January. I would really like to go get it at the factory so I can spend some time with systems engineers but this time of year the weather between Arizona and Colorado may suggest I just have it delivered. Will decide when they say it is ready.
I am posting what I know right now but there is so much more to learn. The Atlas app is one of those areas. I have screen shots of most of the screens in the app but I have not posted them because some date back to the Beta prototypes and I know they have changed.
For those interested ArcTouch is the vendor who wrote the Atlas app. Detail on their site. It is an Android app which is a bummer since I only do Apple stuff. ArcTouch says they do both Android and IOS apps so maybe it can be easily ported over to IOS.
Lightship RV App | Designed & Developed By ArcTouch
A 30% reduction in drag does not result in a 30% reduction in fuel usage nor does it result in a 30% increase in range. It's proportional and non linear, ie., it's relative to speed and defintely not 1-1. At hwy. speeds a 10% reduction in drag translates to roughly a 5% increase in fuel economy, while at or below 30 mph drag ( aero) is less a factor than rolling resistance ( friction).
Honestly, I think you've got the right attitude about it. Better that it's 100% fine off the floor rather than you find an issue when it's 500 miles away (or more).
The 30% increase in efficiency comes from real world measurement of the total system efficiency towing a LightShip behind a tow vehicle without TrekDrive active at 62 mph. Given that situation my F-150 PowerBoost can get 12 MPG towing an Airstream trailer and 16 MPG towing a LightShip. All of that comes from the aerodynamic design of the LightShip and the reduction of around 24 square feet of flat plate area (from 10' high with the AirStream to 6'10" high with LightShip in "Drive Mode"). This is a measure of the actual efficiency of the entire tow vehicle and LightShip assembly moving against the air flow. Given the same variables with TrekDrive active the F-150 PowerBoost will return to around 22 MPG towing the LightShip, combining the efficiency gains from aerodynamics and the efficiency gains from TrekDrive. The aerodynmaic efficiency gains are free. TrekDrive efficiency gain comes at the cost of around 70 kW of battery charge and the time to charge the LightShip.
Even more important when you consider this is only the sixth production conforming LightShip off the line since August. It takes time to get these systems to play nicely together.
Regardless, a 30% reduction in the coefficient of drag at hwy speeds does not translate to a 30% increase in fuel efficiency nor a 30% increase in range. Roughly speaking, at 62 mph ~50% of fuel is consumed overcoming aero drag ( pushing air out of the way) and ~50% is consumed overcoming rolling resistance ( friction), however it's proportional, the greater the speed the greater the aero drag. A 30% reduction in aero drag having zero impact on rolling resistance ( friction), the effective gain therefore in fuel efficiency would be in the neighborhood of a not insignificant 12-15%.
You are simply wrong. The numbers you presented are closer to something you would see in passenger cars. We are talking about comparing heavy, high profile towable recreational vehicles here, not an automobile. And the coefficient of drag is a fixed constant, typically determined in a wind tunnel. It does not change with speed.
Here is a graph comparing a typical 8,000 lb slab sided trailer, 10' tall with a coefficient of drag equal to .9. This would be your typical cheap, high profile trailer like a Jayco. As you can see at 100 km/h (62 mph) the drag is close to 80 kWh/100km while rolling resistance is around 15 kWh/100km. Total energy required at 62 mph is around 105 kWh/100km
Here is the same chart for the Lightship at 8,000 lbs, 6' 10" tall with a coefficient of drag equal to .3. As you can see at 100 km/h (62 mph) the drag is close to 20 kWh/100km while rolling resistance is same as the 10' slab sided trailer around 15 kWh/100km. Total energy required at 62 mph is around 35 kWh/100km
Just as stated in the LightShip references which you clearly did not read, the LightShip is 3 times more aerodynamically efficient than a typical, tall slab sided RV trailer.
Try not conflating Cd and drag force, that's where you got confused. Drag ( drag force) increases by a multiple of 4 with every doubling of speed. That's why I said the greater the speed the greater the aero drag, not Cd. Unfortunately a 30% reduction in Cd does not translate to a 30% decrease in fuel consumption whether it's a moped towing the space shuttle or a Rivian towing a Lighship, it's just a fluid dynamics principle. Have a great rest of Christmas.
Great to see your reviews getting out there, @turbopilot !
Looks like a great list of systems. Since 48V is used exclusively for the canopy actuators, it could be fun to turn that into a full review of the actuator system, mechanicals included.
Happy to tack on anything else this group finds valuable!
Regarding TrekDrive, users do have the ability currently to toggle it on and off during transit (we recommend slowing to a stop first), so that gives owners the ability to optimize when they consume energy. You can also set a lower limit of battery charge on the Atlas, so you ensure you have the energy you want at camp!
Glad you put aerodynamics first. We spent a huge amount of time deciding to incorporate raise/lower functionality into our trailer, but at the end of the day, we thought it was the unlock to true performance, and a must have. That dictated many following decisions, like layout and storage in the vehicle. We also spent a lot of time understanding the impact of airflow at different yaw angles. So - the trailer feels stable and planted in many prevailing wind directions.
More aero = more stable = more safe.
I originally had the canopy actuator system listed separately from aerodynamics but you are right there is more to learn particularly around the automation that controls those motors. So we can visit the subject again maybe when we discuss the 48 volt electrical system since that system is devoted to supporting the actuators.
For all these systems the automation is so important and it really has not had much coverage in all the YouTube factory tours. Hope to change that.
Any time the subject of RV aerodynamic efficiency is discussed it is natural to wonder how do the different trailer designs compare. The market now has a range of towable RV products that offer very different aerodynamic profiles and towing efficiencies.
What follows is a very good summary by Google Gemini AI of the different types of towable recreational vehicles and their relative aerodynamics. AI does such a good job comparing and contrasting complicated subjects.
Comparative Aerodynamic Metrics of Towable Recreational Vehicles
The table below contrasts the high-efficiency EV-focused trailers with the traditional Airstream and the industry-standard "Slab-Side" trailer.
Feature"Slab-Side" Box Trailer (26')Airstream Globetrotter(27FB)Pebble FlowLightship L1 (Road Mode)
Frontal Area (A)~85–90 sq. ft.~65–70 sq. ft.~60–65 sq. ft.~45–50 sq. ft.
Drag Coeff. (Cd)~0.80 – 0.95~0.45 – 0.50~0.30 – 0.35~0.15 – 0.20
Total Drag Area (CdA)~72.0~32.5~21.0~9.0
Aerodynamic ProfileSharp edges, flat rearRounded, semi-monocoqueTapered, shielded bottomTelescoping, boat-tailed
1. The Slab-Side "Baseline" (High-Profile Box)
The standard 26' box trailer is designed for interior volume and manufacturing cost, not airflow.
  • Frontal Area (A): These trailers are typically 8.5 feet wide and 10–11 feet tall. Unlike the others, they often feature roof-mounted AC units and vents that are not integrated, adding significant "dirty" height.
  • Coefficient of Drag (Cd): The sharp 90-degree corners on the front cause immediate airflow separation, while the flat "transom" rear creates a massive low-pressure vacuum that literally pulls the trailer backward at highway speeds.
  • Comparison: Its CdA (total drag) is roughly 8x higher than the Lightship L1 and 2x higher than the Airstream.
2. Airstream Globetrotter (The Rounded Refinement)
Airstream’s major advantage over the "Slab-Side" is the radius of its corners.
  • The Contrast: By rounding the front and roof edges, Airstream reduces the Cd by nearly half compared to a box trailer.
  • The Limitation: While the Airstream is much smoother, it still has a relatively large frontal area. It is "smaller" than a box trailer because of its curved roofline, but it cannot compete with the collapsing height of the Lightship.
3. Pebble Flow (The Fixed-Height Modernist)
The Pebble Flow represents what a "modern" box trailer could be if aero was a priority.
  • The Contrast: It has a similar width to a box trailer, but its active aero tongue and tapered roofline allow air to stay "attached" to the body longer, preventing the massive turbulent wake seen in slab-sided designs.
  • Efficiency Gain: It effectively offers the interior space of a traditional trailer but with a Cd that makes it significantly easier to pull for EVs.
4. Lightship L1 (The Geometric Outlier)
The L1 represents a total departure from traditional RV geometry.
  • The Contrast: Its primary weapon is the reduction of A (Frontal Area). By telescoping down, it hides behind the tow vehicle.
  • The "Boat-Tail" Effect: While the Slab-Side and Airstream have relatively blunt rears, the L1 uses a sharp taper (boat-tail). In aerodynamics, how you leave the air is just as important as how you hit it; the L1 minimizes the "vacuum" effect that plagues the Slab-Side trailer.
The "Towing Tax" Summary
If you were towing these at 65 mph with a standard electric truck (like a Ford F-150 Lightning):
  • Slab-Side Box: You would likely lose 50% or more of your range.
  • Airstream: You would lose roughly 30-35% of your range.
  • Pebble Flow: You would lose roughly 20-25% (offset further if using its active motors).
  • Lightship L1: You would lose less than 10% (near-zero with active propulsion).
