- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
Another great feature of this forum'ware is what you can do with attached images. Other forum'ware you simply attach images and you're done. When you attach an image on this forum you can inline the image as a thumbnail or full size image using the options after you attach/select the image. If you don't then it will be added an an attachment. However, try attaching your image and then insert the full image into your post. Now select the image and notice a toolbar at the bottom of the image. You can add a hyperlink to it so if someone clicks the image it will take them to where you want or you can do other options per the toolbar buttons.
