Lithium Battery Package
Woodglen1
Pennsylvania
Renegade
Vienna
Mercedes Sprinter
Just bought a 2025 Vienna 25RMC ... absolutely love it. We purchased the gen-delete full Lithium package WITH the extra battery. In video's they talked that it could run for like 3 days with AIR no problem .... I need to be educated on how to use it. My dealer did not have familiarity with it. Is there anyone out there that has this full package that would be willing to speak to me for 10 - 15 minutes about what I'm doing wrong?
So Educate me here as I am not familiar with the gen delete option. Assume this means no generator. How much solar do you have? What happens if you have no sun or minimal sun and you are boondocking?
What are you working to learn about the system?
Looked it up and it appears you probably have:
- 330 watt solar panel
- 1200 Ah lithium battery storage (or 14,400 watts)
- A/C has soft start installed
- 13,500 btu A/C
Who created the video that said you could get 3 days of A/C usage?
Rough math:
- 13,500 btu typically consumes around 12 amps on 120v
- This is 1400 watts
- Since your battery holds 14,400 watts, and assuming we can only use 90% of the battery, this would be 13,000 usable watts
- 13,000 / 1400 (watts consumed by a/c) would be a little over 9 hours of a/c time, assuming no additional use by anything else.
- depending on where you are and how hot it is, will impact how many hours a/c needs to run each day
- solar panel only adds 330w in an hour, if conditions are optimal, which they are never optimal for very long since the panel is facing straight up and not directly facing the sun. Not factoring in shade from clouds or trees which will reduce it more.
IF you have great sunny cloudless days, are somewhere where it is not too hot, have nice long days and conserve other power draws I can see where it could be possible to go 2 or 3 days.
If I was wanting to routinely boon dock for more than a day I would investigate a couple options:
- additional solar panels to increase solar generation to at least 900 watts, preferably closer to 1200 watts
- small backup generator to recharge batteries for those times when solar was not available
- keep option open (not just physically but also mentally) for using campgrounds with power if this setup doesn’t quite meet the 3 day expectation. Many people talk about range anxiety with electric cars, this is a similar situation as you will need to closely monitor power consumption, remaining stored power and can you make it to the next time you can get power? Will tomorrow be sunny enough? How hot will it be? How much will a/c need to run?
This can be fun to mange or it can be stressful - it is up to you.
Nice rig!
Gen Delete comes with 2 - 400Amp Smart Lithium Batteries. It renews its charge from an auxiliary Alternator in the lower part of the Engine (3 liter 6) as well as a solar panel. I have the unit and although your understanding was 2 - 3 days, believe me 9-10 hours of constant Air Conditioning is about the Max. There is no engine auto start, when the batterie are low. But a very good panel for finding the State of Charge and power being used is standard (close to the door. I love mine, because Generators without a 12' exhaust stack are not allowed at dog-shows. We run our A?C when all others have not.
I also have a 2025 Vienna TBN with gen delete and 3 TTB 400 batteries. Like it so far, learning by using as it is difficult to get useful information that would apply to my use. I just use it and monitor electrical system closely.
- 13,500 btu A/C
Rough math:
Nice rig!
Wow, all that info and no reply. I enjoyed reading it. Good stuff, thanks.
I am not interested in long term boondocking, but my use would be overnights on the road trips. Maybe a couple nights, water tanks would not allow more for me. With enough power for that and the engine's charging during travel I am thinking it will fit my needs. I have read and am familiar with the advertised specs but practical use is now my interest. First trip out was 4 months with a couple of over night stops unplugged. So far so good.
I just bought a 2025 Renegade Vienna with the Enhanced Lithium Package (2 - 400ahr batteries). I noticed that the inverter/charger seems to be always running. I'm assuming that the solar panel is always feeding the batteries and the inverter/charger is on because of that. Does anybody know if this is normal for this setup?
