- Jan 19, 2021
- Rosemary Farm
- Between RVs
- Toadless
One of the components in tests 4, 5, and 6 on RB’s post #7 seem to be the most likely source for the issue. If you don’t find anything obvious there, locate the starter, disconnect everything from it and try to jump start it. The generator probably wont run but you’ll either rule out or confirm #7. Chances are it will turn the motor over and if it does you can focus on relays, the voltage sense transformer, or the control board (unfortunately a likely suspect).Thank you soo much
