- Dec 19, 2019
- Dutch Star
- 2026 Willys 2 door XR
Since everything was working fine till I decided to power down the coach, I don't think there's a major problem. Now, since I've replaced the main fuse to the inverter, everything is back up to normal except the slide power which I'm convinced is due to a GFI issue. I believe whatever I did in incorrect sequence blew the main fuse and took out the GFI's.Something to consider though, when you're able to read again, is that they have worked this long and you can't discount there is a reason they are tripped.
