Question Monaco Coach Floor Registers
If they are under the cabinets - not on the floor- what coach?
Do you have propane furnace or aqua hot? Either one you will have to have furnace on all zones on the wall thermostat
I have the Aqua Hot System no propane heating system. Big question I guess I'm asking is there suppose to be a thermostat to turn the Aqua Hot on. Because all I have is a rocker switch that says Aqua Hot.
You don’t have a wall thermostat? What year coach?
I do have two wall thermostats for the Duo-Therm units on the roof and there is a place on them that say furnace. The thermostat in the rear has a zone 1 on it but the main cabin does not.
The front thermostat should have a furnace selection on it also. If it doesn’t my guess is that someone replaced the original thermostat with the wrong one. Are both thermostats the same brand/type?
So are the thermostats for the Duo-Therm work together with the Aqua Hot. I can turn on the Aqua Hot switch. The diesel motor turns on but doesn't fire off. Not sure if I'm turning it on totally or I'm missing something.
Yes. Thermostat is used for all functions, heat and AC. If the burner is attempting to run but not firing then your issue is with the Aquahot. When was the last one it was serviced?
I've got a trouble shooting chart for the Aqua Hot and I'm going to start going through it. I'll let you know how it goes. But won't be today. Thank's
