More Reefer Problems
Dan_Frisbie
RVF VIP
Wausau, Florida
Brinkley
G3520
40’ 3”
2017 FR Georgetown, Dometic fridge (can’t remember model #, but will get it if that’s important).
This dang refrigerator is possessed!
When we got the RV in 2021, I thought that the fridge was not cool enough, changed the thermistor with a new bad one. RV shop changed it again and it worked, 35 degree fridge temp.
Went camping, fridge is around 45-50 degrees again.
There are 2 of us camping and we do not leave the door open any longer than absolutely necessary.
Next trip, I allowed it to cool down for a full 48 hours, 35 degrees. By the end of the trip, it’s at 50.
Now we’re moving and using the RV to move all the home fridge stuff. RV fridge on electric for over 2 days, it was at 45 degrees when I opened the door for the first time.
The freezer is at -5 degrees.
I’m so *^&%# mad.
How in the Hell is anyone supposed to troubleshoot this?!
I’m ready to put in a residential fridge.
On our old class c I added two computer fans on the air intake vent for the fridge.
Plugged them in when we turned the fridge on and unplugged when off.
The extra air flow helped quite a bit with efficiency of the refrigerator.
They pulled from the outside and caused additional air to flow across the coils and up the vent on the roof.
Is the thermistor slide to the coldest position? I also added a set of dans inside the refrigerator that attached to the bottom of the cooling fins. I powered it from the power wire fir the light.
Also where in the refrigerator are you measurung the temp. On my residential fridge, the thermometer on the refrigerator wall near the top may read 38*F, yet fresh cut fruit on the top shelf is bordering on freezing.
Yes, thermistor is on the bottom of the fin.
I added a double fan to circulate air inside.
Thermometer is attached to the top shelf.
Outside area is clear and no airflow problems. I put fans on the outside blowing up and the RV center said that they were actually preventing the ammonia from heating up enough, so we unplugged them. I am going to move them to the side vent to not blow directly up the “chimney”.
If I'm understanding correctly, the Dometic is cooling but not continuing to cool as you're using it. You may be opening the door or leaving it open more than you realize.
No.
The fridge is not cooling.
Left running empty for over 48 hours, it got down to 50 degrees inside.
Previously, it has cooled down to 35 (good), then after a few days was over 50.
Freezer is at zero degrees
It is inconsistent.
2 adults and we do not leave the door open for any longer than absolutely necessary.
Outside vent is clear.
There is so much condensation inside that the condensation tray overflowed and the water ran into the RV over the Christmas trip.
I now have extended the hose to drain the water outside the refrigerator exterior panel.
No.
It is inconsistent.
Time to check the door seal!
Look for cracks in the interior plastic!
It may be obvious to some, but not all, that removing humidity via refrigeration is work, no matter if the temperature in the space drops.
A small space can only hold a limited amount of water. If you are producing a large amount of water, you are introducing more water than is posable for the space to contain.
I could be very wrong, but on the Dometic in my previous Forester, I thought higher on the fin was cooler. Is it possible that the thermistor is sliding to the bottom with time and thus warming the fridge?
