Need help deciding on the 2026 Roadtrek Agile
kxu168
Hi all,
We’re considering a 2026 Roadtrek Agile SS and had a question about the battery system. Is the standard 600 Amp battery capacity sufficient to run the air conditioner overnight?
Also, if we’re camping in the summer without shore power, would we need to periodically start the engine to recharge the batteries, or is the battery system typically capable of supporting overnight A/C use on its own?
Thanks in advance for your help!
600 amp hours.....lead acid or Lifepo? If Lifepo4, it will depend on the amp draw of the AC unit, directly related to the btu's it is rated for. There are some new AC units that are more efficient but you don't say....
I have 514AH and can only go for for 4.5 hours depending on the duty cycle, or how often it runs. Meaning how hot it is outside, how cool you want it, and the insulation value of that unit. You should only drain a Lifepo4 down to 20%, so you are going to need something substantial to put that 80% back in the next day.....driving will not do it. I use a 40 amp DC-DC charger when driving. But with nothing else running(not feasible) and efficiency losses in the system, I don't get all 40 into the batteries. So I would have to drive for hours if I was down say 50%. Solar panels on the roof most likely won't get you that 30 amps consistently to help out. A generator is a must.
Short answer is yes. There is a little bit of it depends. Outside temp dictates duty cycle. You could run for a short time but have to be careful and watch the voltage. It harms batteries to drain them to low. And it is difficult to tell State of Charge on Lithium with voltage as it goes and goes and then collapses.
If you want to boondock and run on batteries it will require an education about batteries and such related equipment.
If you provide a few pieces of information you will get better answers.
What kind of batteries do you have, lead acid or LiFePo4?
How many of those batteries do you have, what is their voltage, and what is their amp hour rating?
What AC unit do you have, and does it run on 12V or 120V? How many amps does it draw?
